Kwikset 891 only lock to choose, not Kwikset 910
Hello,
I emailed Vera:
Hello,
For many firmwares, you had the Kwikset 910 door lock model available. Now I can only choose Kwikset 891.
This is a problem as variables are missing and other features such as classes.
https://products.z-wavealliance.org/products/1389/classes
https://products.z-wavealliance.org/products/196/classes
Firmware 1.7.3501
Can you tell me why this is?
Me too I got the 910.
Hope that a good profile for this device will come up soon.
(I did not receive notifications for “BAD PIN”, which is a major part why I bought the device).
BUT, the new 910 I order on Vera (special not so long ago), the manual documentation (and also inside the lock) with the lock stated “Home Connect” and also on the box. So, it’s probably a 891. So it’s “good” for my lock.
Good luck, I’m disappointed with the lock’s range. I will have to move the vp again, that is what support said but they still didn’t directly comment on missing variables the 910 had over the 891 like wakeup interval.
Sent from my VS995 using Tapatalk
