Yep it is, as well as the on-board ones too. I have one that’s connected via some relays to zones, so that I can trigger scenes from a PTK5507 keypad.
Somewhere in the main thread, you will find the luup code snippet that you’ll need to trigger the PGM[/quote]
Thanks Strangely. How do you like the PTK5507? Will the PGM output buttons display their current state? How many PGM output buttons can you configure? Thanks again!
I only have the PGMs currently set as toggles so I’m not sure if they show statuses.
As far as the PTK goes, I’m quite happy with it apart from a couple of niggles like the fact it has the real estate for 8 PGMs in the “control” page, but only displays 4 (unless there’s a programming feature I’m unaware of?)
[quote=“guessed, post:7, topic:177682”]There is no way to inquire on the current state of a PGM, we can only ask that it be “triggered”.[/quote]I believe the question was about whether the keypad could display the status not the plugin.
[ul][li]The EVL sees what’s on the Bus.[/li]
[li]A Keypad uses the same Bus messages to act and display values.[/li]
[li]If the EVL can’t see a value/stateChange (etc) [for something] then there’s a very strong likelihood (with DSC) that neither can a regular Keypad.[/li][/ul]
Yes but as you know, the EVL 2/3 TPI interface doesn’t expose everything that even an IT100 does, and despite the similarities/reverse engineering performed, there are things that never made it into the TPI spec.
Anyway it also doesn’t mean that the keybus protocol itself doesn’t have PGM status since they can be programmed as on and off toggles… Next time I have some programming to do on my panel (there is one change I’ve been meaning to test anyway), so I will test it, despite my doubt it actually does display status… and me blabbering on here for nothing
Anyway all moot really given I’m sure @matchews second post to me was only in regard to the Keypad being able to display PGM state
