[quote=“johnes, post:19, topic:185489”]8.c states:
“When motion is detected, a message is sent to the Nexia Bridge and the Sensor remains in an active state until no further motion occurs for a period of 4 minutes. Any motion detected before 4 minutes will cause the timer to reset for another 4 minutes. (Motion reset time may be changed for test purposes. See Maintenance for more information.”
- Jumper on both pins of the TEST connector for five second motion reset time
ibrewster seems to say that I should only be getting one fire, whre the manual suggests that any motion will cause the timer to reset (the example says 4 mins, but I have the jumper set to 5 seconds. I would set it to the 4 mins setting, but I have lights that I want to turn off if no motion in 30 - 45 seconds. 4 minutes would be overkill.[/quote]
The manual says “Any motional cause the TIMER to RESET for another 4 minutes” NOT “Any motion will cause a message to be sent to the Nexia Bridge”. So basically, from the quote that you presented, your sensor works as follows:
- When motion is first detected, a signal is sent and an internal timer is started at 4 minutes
- When additional motion is detected, the internal timer is reset (nothing else - i.e. no motion detected signal)
- After no motion for 4 minutes, the sensor goes into an inactive state (which should, I believe, signal the controller)
- Any additional motion after that will send another “motion detected” signal.
- The 4 minute interval can be reduced to 5 seconds by putting a jumper across the TEST pins, but as Richard said, this will reduce battery life, and as the name of the jumper indicates, is intended for TEST purposes
So in your case, you can either have a 4 minute off timer for the light, or you can leave the unit in test mode (with the caveat that it will kill battery life) and set a timer when it goes inactive. When the timer expires, shut of the light. If motion is detected again before the timer fires, cancel the timer.
