KARMA - my last post
I congratulate all the clever people who has nothing else to do except giving freely bad Karma to me! :-*
Karma has NO ADDED VALUE in a forum, except for frustated anonymous people…
[quote=“chris66, post:1, topic:179218”]I congratulate all the clever people who has nothing else to do except giving freely bad Karma to me! :-*
Karma has NO ADDED VALUE in a forum, except for frustated anonymous people…[/quote]
I do agree, and these thing though might have good intent or designed to add fun, they can be used as weapons behind the cover of an anonymous click.
I hope that it would be removed as seeing forum member leave or new member get annoyed would not provide any advantageous.
Yeah this karma thing is plain stupid. Why did chris66 get some “bad karma”? And for that matter, why did I get some? Nobody ever told me I was doing this to upset them or told me I was giving misinformation.
::slight_smile:
Karma should be weighted… Positives should be easy to give but negatives should be weighted by amount of time/number of posts/positive karma:
-New user: Negative karma ranks at 0.00001
-Posts: 2-10: 0.01, 10-100: 0.4
-Karma: 10+ negative karma 2
something like that
I’ve noticed the Karma, but I never really gave a second thought to it. Does Karma affect anything or is it just a “Look at my Karma!” type of thing?
@chris66, I wouldn’t give it a second thought about the negative Karma. just keep on keeping on :slight_smile:
i gave you some positive karma, chris
someone gave me some negative - oh well
I just gave you all some good karma because you’re such great folks. :wink:
I would certainly vote to have it removed, for me it adds no value,
I used it once but that was more to see what it did.
If they did it so when you hit 100 karma points and you get a free Vera - then I might be tempted :wink:
By the way - have I said recently how great you all are ? :wink:
there’s some karma for you, parkerc
i’ll vote for removing this as well
I vote to remove karma too. I wonder who and why I received it from
I really think this needs to end.
The karma function doesn’t serve it’s intended purpose. At least not on this forum. At the very least the negative karma portion needs to be removed. Giving a random internet brother a +1 is easy and great but this system is highlighting the negative. If a forum member is so troublesome that they need a sign warning other members to stay away maybe they don’t need to be here. Maybe good moderation is better than bad karma.
Who enabled it? We need to communicate with this person to assure them that it needs to go away.
I don’t think it has created a method by which one’s responses or general contributions can be judged as valid. I see people accumulating “negative karma” all the time and I see no gross misinformation being posted by them or any abusive behavior. Even RTS has a double digit # of negative karma points!!!
Probably because he tortures puppies and kittens or some endangered species.
I have a bunch of positive “karma” points. God knows why. ::slight_smile: My advice is dangerously ignorant at best! I also have a bunch of negative points. Well, I can understand those. I probably advised people to wire their switches in such a way that their houses burnt to cinders.
Woops.
Still it’s garbage.
Those who keep an eye on the forum will know who is who. The karma system only confuses this for newer or casual members/readers.
Who can I contact to discuss this issue?
If your not pissing somebody off…your not doing anything worthwhile :wink:
@S-F,
It would have been one of MCV’s team that added the Karma module, since it’s an Admin-only function to add that type of module to SMF. It seems to have been added at around the time they made Newbie status 1-post instead of it’s previous 25-posts, and cutover to approving the first post of every new user (which, in itself is an admin nightmare)
If you want to outreach, then @mcvflorin would be your best bet. I believe you’d have enough support to have it removed, but the posts showing issues/concerns are scattered in a few places. A poll for a short period would fix that if they’ve not seen enough evidence otherwise.
RTS has a double digit # of negative karma points!!! Probably because he tortures puppies and kittens or some endangered species.
I have it on good authority that the Bald Eagle tastes like chicken ;)
Shields up ... I pretty much ignore the negative Karma ...
Sometimes I wonder if I get negative Karma because people do not like the answer … which is valid if the answer is based on my opinions or my world view … but if its based on facts … it’s like shooting the messenger.
If I had received one negative Karma point for every bug I have released … the negative would be higher …
It reminds me to stay positive, do a better job at testings, and try to explain things clearly …
I have seen somwhere that Da-jojo was pretty frustrated ower his -karma.
And I understand him, someone was bullying him, and that is deeply unfair.
He is participating in the forum with a lot of interesting stuff.
That kind of mobbing should bee stopped.
Regards CE
Maybe there should be a post where you could see how many karma +/- one have GIVEN to others.
That would show if you are only negative or what…
Regards CE
