javascript tab
I am trying to find any example of a javascript Tab like explained in the doc http://wiki.micasaverde.com/index.php/JavaScript_API
I d like to create a device which has a specific tab drawing that I would do in javascript but would like to see how one can do this and call set_panel_html (html) at the end.
Can this html parameter includes a for instance ?
[tt]http://forum.micasaverde.com/index.php/topic,7750.msg49749.html#msg49749 / J_DataMine1.js[/tt]
This is a very simple JS tab: J_VistaAlarmPanel1.js in tags/2.44_UI5 – Honeywell Ademco Vista Alarm Panels via AD2USB
And this is how it’s referenced in the Json file:
    "Label": {
        "lang_tag": "cheat_sheet",
        "text": "Cheat Sheet"
    "Position": "1",
    "TabType": "javascript",
    "ScriptName": "J_VistaAlarmPanel1.js",
    "Function": "showCheatSheet"
Edit: Ap15e was faster than me. :slight_smile:
Excellent ! thank you both
A couple of my plugins use JavaScript tabs extensively. Like dataMine, these are not simple examples.
Caddx alarm panel
CurrentCost EnviR
