Does anyone else have a problem with their Jasco dimmer plug Ver 3.0d where when you send the off command, it dims a bit, then turns on to full brightness? I’m using a vera light as the controller.
A dimmer switch plug that doesn’t turn off is pretty much useless.
I received 4 Ver 3.0d date code 1243 from amazon and 1 from Walmart.com same version/date code and they all exhibit this issue. The other 3 in my shipment from amazon were Ver 3.0c and do not have the issue. No issues with my original Ver 3.0a modules either.
Need to find a way of not receiving any with 3.0d on my next order. Maybe order the evolve ones.
Wayne
