IVMS
Hi Guys
I have 8 CCTV Analog Cams connected to the DVR Card Hikvision. Software that I’m using for the Server is IVMS 2000, for the PC client is IVMS 4000 and for the Iphone is IVMS-4500. Everything is working fine but i am wondering is there any way that I can also connect them on Vera3 so i can look through the IVERA Iphone app
Also I can see my cams through HTTP screen shot attached
Cheers
since it CCTV it requires a http stream or picture from the software you use. that would be the IVMS 2000. this uses some protocol to speak to the IVMS 4000.
you would have to look in the SDK or Docs that come with the device to find out it can stream mjpeg or asf or jpeg over http. and then put this in a manual generic ip-camera device on the vera.
get some docs where we can find how to speak to the IVMS 2000 and we can see if we can come up with a solution :slight_smile:
