I need BETA testers who have more than 1 VERA system tied to their username. Please send me an email at support@instruodev.com if you would like to do some initial testing for me.
Also anyone who is on UI 6 that wants to test out iViri please let me know, I plan to start BETA testing that this upcoming week.
Can we test on iPhone 4s. I don’t have any of the above requirements.
[quote=“dbmet, post:3, topic:180425”]Can we test on iPhone 4s. I don’t have any of the above requirements.
Sent from my iPhone using Tapatalk[/quote]
Yes, send me an email at support@instruodev.com with your UDID if you were not part of the original BETA testers. I want to know that the issues are resolved on iphone 4s.
App is working great on iPhone 4s. Still testing but it’s much much better !!! Thanks for your hard work !!
Just jumped on the bandwagon and upgraded to UI6. I was not a original beta tester for your app, but if you want me to test iViri on my system let me know! I have been using VeraMate earlier, but am interested in skipping my iPhoneLocator app.
Just jumped on the bandwagon and upgraded to UI6. I was not a original beta tester for your app, but if you want me to test iViri on my system let me know! I have been using VeraMate earlier, but am interested in skipping my iPhoneLocator app.[/quote]
Email me at support@instruodev.com. I have some stuff that I need to have you run for commands against your vera before I can get the app portion coded, once done it will be in the app fairly quickly and then I will get your UDID and get you added to the BETA list to start testing out the apps functions.
Sorry! :S UI6 turned out to be a much more unstable system then I had hoped. Had to format my Vera and reinstall everything. I am now back to good old UI5 again…
No worries, same thing I did when I was developing iViri. I thought to myself hey look I can get UI 6 and start testing against it, then noticed I was very unhappy with its stability so I downgraded and started over.
Hello,
I installed the app today, and it launched only once… I found my rooms, and the the app said ‘Checking job status’… and crashed.
Now it does not launch anymore (in fact it launches, and then exits - but the app is running background and still stuck on the ‘checking job status’ screen)…
I have an iPhone 4 and iOS 7.1.
What’s the next step ?
[quote=“Theduck38, post:10, topic:180425”]Hello,
What’s the next step ?[/quote]
Is this v1.2? Or did you download from the apple store today and it isn’t working?
In fact I don’t know which version it is as I cannot open it anymore…
I downloaded it today, so it seems to be 1.1 from what I can read on Apple Store.
[quote=“Theduck38, post:12, topic:180425”]In fact I don’t know which version it is as I cannot open it anymore…
I downloaded it today, so it seems to be 1.1 from what I can read on Apple Store.[/quote]
Under General Settings on the iOS if you scroll down to iViri, do you have Mios User/Password and Vera IP address populated?
[quote=“jpete7683, post:13, topic:180425”][quote=“Theduck38, post:12, topic:180425”]In fact I don’t know which version it is as I cannot open it anymore…
Under General Settings on the iOS if you scroll down to iViri, do you have Mios User/Password and Vera IP address populated?[/quote]
Yes everything is set. It worked for a few seconds with those parameters…
V1.2 is submitted to apple. If you don’t want to wait we can get you on a beta version to test out. I think the changes in v1.2 will resolve your issues.
OK, let’s see v1.2…
Email me at support@instruodev.com and provide you UDID of you iPhone device. Then go to test flight and register you iDevice.
@jpets7683 I am also having geofences disappear in 1.2. I had a geofence which worked a couple times not work so opened the app. I found the geofence was open (detailed displayed) so I tapped Save but nothing happened. I had to terminate and relaunch the app then the geofence was gone. Happy to help debug/test if if there I anything I can do to help. Thanks.
[quote=“mda, post:18, topic:180425”]@jpets7683 I am also having geofences disappear in 1.2. I had a geofence which worked a couple times not work so opened the app. I found the geofence was open (detailed displayed) so I tapped Save but nothing happened. I had to terminate and relaunch the app then the geofence was gone. Happy to help debug/test if if there I anything I can do to help. Thanks.
I am very sorry for the experience you have had with v1.2. I spent 2 full days completely rearchitecting the geofencing code. The reason being is when I first started the project I never anticipated how big this functionality was going to be for users and it was only tested with one geofence and once it was working I never touched it. After messing with it I noticed how unstable it is when adding, removing, updating, inactivating, activating, etc… So I stopped everything I was doing to figure out a new way to go about doing this and it is finally stabilized in v1.3. I will take you on as a BETA tester if you are willing but if you want to hold out as v1.3 should get released relatively quickly that is okay to. Just email me your UDID at support@instruodev.com and register your device with test flight. Thanks for your support with this app and hopefully this next release is a turning point for all users.
