I have the Ivera APP and it works ok but I can’t get the power metering readout to work on a switch - it works on UI4.
I’m using Vera2, Evergreen on/off switch (AN158) with power meeting.
When controlling the device via UI4 the actual watt usage is displayed against the device.
Hello, is your device reported as “urn:schemas-micasaverde-com:device:PowerMeter:1”. If so, iVera doesn’t yet support this device but could add it in future release.
