As mentioned previously, a software update for iVera was sent to Apple and finally got approved! You can download it from the AppStore application.
iVera 1.0.1 adds support for UI4 as well as support for some new devices (Window/Door Sensor, Smoke Detector, Humidity Sensor and Window Covering), some bug fixes and access to Demo Mode.
Important: some changes made to this build require a refresh of your configuration after upgrading from iVera 1.0. To do so, go to Settings->Advanced and click on “Reset All Settings”.
As soon as I can control two Vera’s (both my main home and my lake house) I will buy this app in an instant. Until then I will continue to use the free web iphone control from micasaverde.
Yes, iVera works with Vera/Vera2 and UI2/UI3/UI4. Could you try to do a "Reset All Settings"? To do so, go to Settings->Advanced and click on the red button ...
