It's taking too long to save data on Vera 3/UI5
I am having very long delays before data gets saved on my system. The delay is now around 4 minutes. This occurs after anything like changing or creating a new scene, changing triggers…basically anything that requires a save. The system is working fine as far as I can tell. Is there anything I can check or do to help solve this issue? It created a support ticket yesterday.
Hi lemrock,
Did you get anywhere with this?
My unit too is taking an age to save data.
[quote=“junglewave, post:2, topic:190951”]Hi lemrock,
Thanks[/quote]
I’m still waiting for someone from Vera to get back to me. The time delays have increased over the weekend. I’ll post any solution they find.
Having the same problem, as well as other anomalies. I discovered some time ago that when the Vera3 starts acting up like this, the only way to make it work again is: Run a full backup, do a factory reset by holding the button 30 seconds, reset the z-wave network, reload the firmware selecting factory reset, and then load the backup. It then runs OK for a while.
Mine has been doing this also. Seems it affects saving and also the scene run button.
