My apologies if this has been mentioned here already but I didn’t see it:
Every single time I rotate my phone while using AutHomation, all my devices disappear.
For example, if I open the the app, then go to Devices > All, I see all my devices. Then I rotate the phone and the app changes orientation, but all the devices disappear. If I rotate back, I still don’t have my devices. I have to back out one step then go back in and they’ll be there. Refreshing doesn’t bring them back, but changing the sort order does.
This is using AutHomation HD (which is all I can get on my Galaxy Nexus, for some reason).
What version of AutHomationHD are you running? The one from the market version 2.0.3.x? Or the 2.1 beta from the subforum? AutHomationHD is what you want. It is meant for tablets and phones that run Android 3.2 and newer.
You’ll need to remove the current version as there have been some major changes to the backend of the app’s database. It is also better formated for the Nexus 7. If you do give it a try, let me know if you still have the issue. It appears to be working fine on my Nexus 7.
I just downloaded the new version 2.0.3.1 and this has the same issue. when I rotate my galaxy S3 all devices and scenes dissapear.
The previous version I downloaded (last week) didn’t have this problem, before that (about 3 weeks ago) the issue was there as well.
Is there a quick fix for this , since it is quite annoying.
