Issues with setup of USB UIRT on Vera2 running 1.5.346
Attempting to get a USB UIRT to control an Audio Authority AVM 562.
http://www.audioauthority.com/downloads/ir/AVM-562.xls
Have hex codes for remote - USB UIRT isnt even responding correctly in Vera.
Any ideas?
Any more details on what you mean by it ins’t responding and what have you tried?
-Can you see it added it as a device?
-Can you see any life from it like an LED flashing?
-Have you created a Plugin for the AVM562?
-Is this Plugin associated with the USB-UIRT
I can see the USB-UIRT. When I attempt to use the auto learn procedure - the lights blink, but I get a failure. I wanted to create a generic device that I could then go in and manually exit the HEX
Why not try to edit the files in this thread:
http://forum.micasaverde.com/index.php/topic,4542.0.html
OK - edited these 2 files and uploaded them to LUUP folder.
Now figuring out next steps…
Note that [tt]S_Display1.xml[/tt], that you have referenced in your [tt]D_*.xml[/tt] file, doesn’t exist. It may cause the plugin to fail (or it may skip over it, I don’t remember the exact behavior)
Once you upload these, you need to create a device from the D_*.xml file, using the menu:
Apps >> Develop Apps >> Create device
At that point, it should show up in Advanced scenes, and the only thing left is to associate this with a Channel from the SQBlaster/USB-UIRT/GC-100 type IRTransmitter device
If you need to test it afterwards then you can either create a scene (advanced tab), or use the following page:
http://X.X.X.X:3480/data_request?id=lu_invoke
