Issues with heating controllers
Since my UI5 upgrade I’ve lost the ability to control the hot water in my house.
I have a Horstmann ASR-ZW controller, which under UI4 was detected as an HVAC_ZoneThermostat1 - it now appears as Heater1 and no amount of tweaking has allowed me to do what I need to, which is switch it on and off (HeatOn).
Previously the buttons appeared to switch the unit on and off (Heat/Off) - but now I only see a temp control.
After looking at the old scenes I can see I sent a SetModeStatus command witha value of HeatOn to do this - but this is no longer available, the closest is SetStatus which does nothing as far as I can tell.
Also, this device, my HRT4-ZW thermostat and my AS2-ZW all from Horstmann do not show up under ‘Climate’ despite all being detected as thermostats (Heater1).
It’s odd to find an upgrade reduces functionality - any ideas?
