There’s been a change at the MiOS service; a new server has been added and HomeWave doesn’t know about this server. This affects the ability of some users to connect remotely to Vera.
I’ve submitted a version to the App store to deal with this issue. The new version will always first try to connect to the server recommended by the Vera discovery message, and then try the known MiOS servers one by one. It also adds the ability to override Vera and connect to an arbitrary URL to either a MiOS server or directly to your Vera (via an open router).
The “Direct connect” setting should not be necessary in normal situations.
If for whatever reason the app doesn’t find the right address for the MiOS gateway, you can enter the address manually in that field.
If you are able to access your Vera directly from the Internet, then enter the Address + port of your Vera in that field, and enable Direct connection. You can do this by setting up port forwarding on your router to your Vera, though this is not recommended due to security concerns (there’s no password to protect your Vera in this case)
ok thank you for the info
Well my nat is configured I redirect port 1492 to port 80 of my vera but it does not work with homewave
by cons it works very well in chrome monnom.dyndns.org: 1492
I do not understand why it hangs on homewave you would use it as the port 3480 of the vera? or other
[quote=“intveltr, post:6, topic:173410”]The “Direct connect” setting should not be necessary in normal situations.
If you are able to access your Vera directly from the Internet, then enter the Address + port of your Vera in that field, and enable Direct connection. You can do this by setting up port forwarding on your router to your Vera, though this is not recommended due to security concerns (there’s no password to protect your Vera in this case)[/quote]
if you have enabled secure this vera it has.
[quote=“davidd1205”]I redirect port 1492 to port 80 of my vera but it does not work with homewave
by cons it works very well in chrome monnom.dyndns.org: 1492[/quote]
For god’s sake, turn that off right now. You are enabling anyone in the world to to control your Vera without any access control.
[quote=“Da_JoJo, post:9, topic:173410”][quote=“intveltr, post:6, topic:173410”]The “Direct connect” setting should not be necessary in normal situations.
if you have enabled secure this vera it has.[/quote]
i have no secure vera
i want to test a control direct but with homewave it’s impossible for me
it’s still weird
better setup a VPN connection to your home-network and then you can connect straight to your vera without exposing it to the wide web.
like futzle pointed out, it is not a good idea to forward vera ports… vera uses its own port-forwards via UPnP and this can cause conflicts also.
