I have the Pro version installed on my motorola xoom tablet running Ice Cream Sandwhich. All seems to be working fine with the exception of 1 item. When adding the Launch Application widget to a dashboard board, nothing happens. I add the widget, select the application to launch and it simply returns me to the dashboard without successfully adding the widget. This feature works on my phone Nexus 5 running Kit Kat. Is this an OS issue, or a issue due to the tablet itself ?
has anyone seen this before…I would ideally like to set up this tablet as a wall mounted tablet…but would like this ability…
Thanks !
We have had several reports about this issue last weekend, and we have been unable to reproduce it for now
Would you be able to send us your debug logs after having tried to add the widget ?
(Little guide : https://imperihome.zendesk.com/hc/en-us/articles/200732217 ; and please send us your debug id on our support email address : contact@imperihome.com)
Thanks !
Thanks. I have sent the logs and the debug I’d to the support address. I look forward to hearing if it can be resolved.
Thanks a lot.
Bug has been spotted and resolved. A 2.0.11 version is currently publishing on the play store and has this bug fixed
Best,
Great. I was about to chime in. I have the same issue.
Do you confirm the issue is fixed in 2.0.11 ?
Thanks,
[quote=“ImperiHome, post:6, topic:179274”]Do you confirm the issue is fixed in 2.0.11 ?
Thanks,[/quote]
Yes… works perfectly! Thank you.
