Issue with ecolink tilt sensor
I have a ecolink tilt sensor installed on my garage door. I was working fine, until the update of the latest UI7 firmware. After that, it frequently gets tripped although the garage door is actually closed…
Is that a known firmware issue? Any fix available? Every new UI7 updates introduce new issues more than they fixed the old ones. What are they doing…
[quote=“glavewu, post:1, topic:188589”]I have a ecolink tilt sensor installed on my garage door. I was working fine, until the update of the latest UI7 firmware. After that, it frequently gets tripped although the garage door is actually closed…
Is that a known firmware issue? Any fix available? Every new UI7 updates introduce new issues more than they fixed the old ones. What are they doing…[/quote]
Could be coincidental… lots of problems with these misfiring. i fixed mine by opening the unit and bending the sensor tube a bit. Has worked great since.
I have had the same issue. It seems to have settle down a bit now, but it is useless if it gives false alarms. I will wait and see I guess.
Mine started doing this when the battery was starting to get low.
It does make it less than useful as a security feature, because of the false triggers.
How long can the battery last? Mine is only 5 month old and it is always 100%, all my ecolink sensors are 100% battery, some of them are about 1 year and I’m thinking their battery report may have some issues.
I pulled mine from service (UI5) - it was not reliable enough. I added a wireless tilt sensor to my DSC alarm system instead, and it has been flawless…
Ever sense i bent the little tube, I’ve NEVER had a single false reading.
