Issue with Aeon ZW080-A17
I just got a siren from Aeon, the ZW080-A17 and having trouble adding it. I’m using VeraLite UI7 latest firmware and in the add device/alarms, I can find one called Aeon ZW080-C15, though not exact same name, the instruction shows the same device.
I followed the instruction and put the siren next to my Vera. I tried at least five times and every time after Vera says “successfully exchange security key”, the process stuck there until the timer count down to 0. Actually there is a device added but the type is appliance module and the logo is a light bulb not a security siren. Then I unpair device and delete it redo the process. I even used the 20 sec long press to reset the siren according to the manual. But still unable to finish the process cleanly.
I tried to turn on the device and the siren alarmed, but weird thing is my garage door tilt sensor tripped right after I turn on the siren while the garage door is actually closed and the tripped tilt sensor won’t untrip after some time I have to manually untrip it…
Also the siren generates some low volume but high frequency noise. I can easily hear it when the room is quiet.
Anyone has ideas about fixing this issue? I search the forum but can’t find a solution. Thanks in advance.
I also bought this siren. Do you still have issue with it?
The issue is a unit defect, the seller has sent me a replacement and it works fine now, no noise anymore.
