Issue setting commands for a scene using U13 1.1.228
I’m using the lastest version of the new flash UI and I’ve run into two issues that worked perfectly before.
  1. When setting up a scene I tried to select (unchanged - after 1 min - turn lights off) which used to work but now when the first step is unchanged it just switches back to set level. It will not save as unchanged so I can’t have a delayed off. Has anyone else seen this?
  2. I can’t find how to make a scene hidden?
  3. I tried to make changes to a scene that was associated with a leviton controller but even after making changes and manually selecting update controller the changes that were made did not get updated on the controller.
Jose
bump
  1. We’ve tested the commands into scene and they are working fine
  2. We will add this soon, we’re working on it.
  3. We will test this and see if we can reproduce your issue regarding the Leviton scene controller.
