Is there any way to undo this?
I recently decided to upgrade my Vera lite to a Vera edge and I followed the instructions to perform a “controller shift” which copied all of my info from the lite to the edge and in the process made the lite a slave controller to the edge.
I’m having second thoughts about using the edge so I disconnected it and went back to the lite. Now that the lite is not the master controller, I’ve lost some functionality. I can’t even add a new device to it.
So can I change the lite back to a master controller without having to reset everything? I haven’t been able to find the answer yet.
Thanks in advance
Can you fill out the form below and send us a trouble ticket ?
http://support.getvera.com/customer/portal/emails/new
Be sure to include your Vera unit serial number and the tech support access code. You can enable it by going to Settings > Tech Support and then clicking on the Enable button at the bottom of the page.
We’ll look into it right away and get back to you shortly.
Thanks.
