Hi All,
I have a Kwikset lock on my detached workshop which does not seem to work very reliably. It is about 25’ away from my back door, which itself has a Kwikset lock and has 3 Leviton switches installed right beside it. Just inside the workshop door are another 3 Leviton switches, and a Wayne Dalton thermostat. My hope was that at least some of these should be helping to relay messages around. I should also note that the thermostat and all three lights in the shop work very quickly and reliably.
I tried running a heal just against the workshop door lock, and it looks like it can see lots of neighbors, but the stress test seems pretty bad if I am interpreting things correctly. Any ideas on what might be wrong or what I can do? I am running the latest 1245 with 3.20 z-wave firmware and have mios routine enabled.
Thanks in advance… am finally doing pretty well with Vera/z-wave if I could get this issue licked!
Here is the heal report:
11-04-25 16:14:12 report for HealNetwork. Successful: Y Updated net: N mr_only:0 Job ID: job#1708 :heal network (0x75e5d0) P:71 S:5
=======NEIGHBOR NODE UPDATES=======
Node 35 Device 38 Workshop Side Door neighbor nodes updated 0 times (incomplete 1 in a row 0), woke up 0 times configured: YES
=======STRESS TEST RESULT=======
Test: NOP Sent 2 test frames and 2 succeeded (100%) with average of 10.071112 seconds and maximum of 11.666750 seconds
Test: Basic_Get Sent 2 test frames and 0 succeeded (0%) with average of 0.000000 seconds and maximum of 0.000000 seconds
Test: Secure Sent 2 test frames and 0 succeeded (0%) with average of 0.000000 seconds and maximum of 0.000000 seconds
Test: Get Node Info Sent 2 test frames and 2 succeeded (100%) with average of 7.528903 seconds and maximum of 13.748858 seconds
–HEALTH SCORE: 1–
=======NEIGHBOR NODE RESULT=======
Node 35 Device 38 Workshop Side Door took 0.28091000 seconds to report neighbors: 1,4,15,20,22,23,26,27,28,29,31,
Inversely:
Node 35 Device 38 Workshop Side Door is seen by: 1,4,15,20,22,23,26,27,28,29,31,
=======EDGE NODE PROFILE=======
=======DETAILED LOG=======
–Stage #1 started: 11-04-25 16:14:12 completed: 11-04-25 16:14:12 successful: N
—11-04-25 16:05:44 Job unknown
–Stage #2 started: 11-04-25 16:05:44 completed: 11-04-25 16:14:12 successful: Y
—11-04-25 16:05:44 Pass 0/5 Updating neighbors for node 35
—11-04-25 16:06:36 Job job#1709 :heal_neighbor_node 35 (0x851f10) P:70 S:4 was Successful
—11-04-25 16:06:36 Neighbor Update Done
–Stage #3 started: 11-04-25 16:06:36 completed: 11-04-25 16:14:12 successful: Y
—11-04-25 16:06:36 Routing update node 35
—11-04-25 16:06:36 Job job#1710 :heal_routing_node 35 (0x76ec98) P:70 S:4 was Successful
—11-04-25 16:06:36 Routing update done
–Stage #4 started: 11-04-25 16:14:12 completed: 11-04-25 16:14:12 successful: Y
—11-04-25 16:11:08 Calculate Routes Done
–Stage #6 started: 11-04-25 16:14:12 completed: 11-04-25 16:14:12 successful: Y
—11-04-25 16:11:08 No battery nodes
–Stage #7 started: 11-04-25 16:11:08 completed: 11-04-25 16:14:12 successful: Y
—11-04-25 16:12:45 Node Details heal 35
—11-04-25 16:13:58 Node Details heal 35
—11-04-25 16:14:12 Stress test Done
