So my restarts are still going on non-stop. CS says wipe it and start over. So, I will try, but I do not want to have to manually exclude 50+ devices one at a time. Is there no way to put the controller into an exclude mode where I can just keep pushing the next button and they unpair?
No. There isn’t.
actually there is but not by using the UI. I am using Homewave on iOS and I was able to use it set the controller on include or exclude mode.
I am sure it is a Luup command.
http://wiki.micasaverde.com/index.php/Luup_UPnP_Variables_and_Actions#ZWaveNetwork1
under remove nodes
