Unfortunately I have the same problem. I have bought Vera to control my boiler and make my heating system more convenient.
I reset my Vera twice, and always after few days happen the same story - bugs in logs, scenes doesn’t run, schedule not work.
It seems, that a reason of it is learning process which use memory and processor to calculate room parameters . For now I’m looking for better solution and use other plugin than SVT - maybe someone of You has ideas ??
I’m going to try a combination switch with scenes - maybe it will be better.
I took off SVT, Combination Switch, Weather plug-ins and install only PLEG with own logic - now Vera work perfect ;D .
Maybe it is suggestion for others.
Maybe it is suggestion for others.[/quote]
this is what I have been thinking also, but for me it’s a problem how to control it through the Vera mobile application. It should somehow appear as device there. So how this can happen? I guess I need to create a device with all the necessary files? Any ideas?
