Is the a Guide for first time install and setup
Hi there
I am using UI5. Is there a step by step guide for installing VeraAlerts on Vera and on Android and how to set it all up.
Many thanks in advance
Wondering the same thing!
Banging my head to the keyboard here… :cry:
A noob ??? proof guide would be very much appreciated!
+1 to that.
I have it installed on my Samsung with coms to Vera. After that I’m lost.
  1. Install on Android
  2. Register your VeraID on android (Settings Tab)
  3. Record your Vera ID
  4. Install Plugin on Vera
  5. Create Vera Mobile Profile (Profiles Tab)
    Set the Vera ID from #3
  6. Goto Settings
  7. Make sure Notifications are checked.
  8. Settings on the bottom for each use (Lower Left)
    a) Select Each User (Should be minimally two user)
    b) Select Profile to use for that user (Lower Right)
  9. Save Chagnes/Restart Vera
  10. For devices of interest … Create a Notification (Notification Tab on device)
    Specify the user …
    Repeat 10 for devices of interest.
  11. Goto Notification Configuration tab on Vera Alerts
    View/Override default notification for each alert.
    Save/Reload Vera
    You need to do this step when ever a notification is added/changed.
There are a LOT of other options … this will get you started.
