I’ve had an SSD connected to my Vera Plus using a powered USB hub for several years and have used the extroot script to move the filesystem there. Yesterday the USB hub failed so I had to replace it. At the same time I updated the Vera firware to the latest 7.31. AFter doing that I tried again to use the SSD for the filesystem. But going to Settings → Logs and trying to Store logs on USB device (several times) I’m not sure where I stand. Using PuTTY to log in and look at filesystems this is what I see:
root@MiOS_xxxxxxxx:~# df -h
Filesystem Size Used Available Use% Mounted on
rootfs 28.7G 226.9M 27.0G 1% /
/dev/root 8.0M 8.0M 0 100% /rom/rom
tmpfs 124.3M 388.0K 124.0M 0% /tmp
/dev/mtdblock6 10.6M 1.3M 9.3M 12% /rom/overlay
overlayfs:/overlay 10.6M 1.3M 9.3M 12% /rom
tmpfs 512.0K 0 512.0K 0% /dev
/dev/mtdblock10 50.0M 12.0M 38.0M 24% /rom/storage
/dev/mtdblock10 50.0M 12.0M 38.0M 24% /rom/etc/cmh-firmware
/dev/mtdblock10 50.0M 12.0M 38.0M 24% /rom/etc/cmh-backup
/dev/sda1 487.8M 2.9M 455.4M 1% /tmp/log/cmh
/dev/mtdblock9 9.8M 9.8M 0 100% /rom/mios
/dev/mtdblock10 50.0M 12.0M 38.0M 24% /rom/etc/cmh-ludl
/dev/mtdblock11 19.3M 1.2M 18.1M 6% /rom/ezmi
/dev/mtdblock11 19.3M 1.2M 18.1M 6% /rom/etc/cmh
/dev/mtdblock5 8.0M 8.0M 0 100% /rom/mnt/mtdblock5
/dev/sda2 28.7G 226.9M 27.0G 1% /
So where is the Vera running from? What is on the hub and what is on the SSD?
Also - where is the LuaUPnP.log file? There’s an old one in /tmp/log/cmh but I can’t find the current one. I know it’s out there somewhere because http://[my Vera IP address]/cgi-bin/cmh/log.sh?Device=LuaUPnP displays it in a browser.
