I’m looking for a method of initiating a VeraPlus Scene by clicking a windows 10 desktop icon.
Is it possible using either a browser or Putty / WinSCP with a command line to accomplish this?
I’ve searched the forum and the closest I found was to run ImperiHome / bluestack / Window 10 which I think is too convoluted to be a reliable solution.
[quote=“JohnRob, post:1, topic:194053”]Hi,
Any ideas?
JohnRob[/quote]
Check here, there’s probably more commands available as well:
I think the Luup_Request is just what I’m looking for.
I looked at Grasshopper as well. Seems interesting but I tend to shy away from apps that request a lot of permissions. Perhaps they are needed but there seems to be a lot of them.
tomtcom pointed you to the right page, but the wrong section. Rather than the scene section that he linked to, you need the action section.
Simply create a desktop shortcut to the URL pointing to the desired scene number.
http://VeraIPAddress:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=999Of course, this will cause your browser to open. If that is intolerable then I’d suggest wrapping the URL call in a batch file or PowerShell script that uses something besides your browser to make the call or immediately closes the browser after opening.
