Well we never had these “Heat Sensor” devices on Vera UI7 for Fibaro Dimmer 2 modules. Right or wrong.
But the Overheat is an alarm report sent from the device to the controller.
I’m not sure why that requires a “Heat Sensor” child device?
Maybe to act as a trigger in your rule might be one good reason why you might want it as you say. If that’s the way it is going to work?
But I thought an alarm report was just that, a report / alarm frame sent into the controller by the device, which presumably would result in a notification of some kind, with no need for an actual child device to be present.
Personally I wouldn’t want loads of “Heat Sensor” devices cluttering up my UI and would elect to hide them if possible.
Homeseer shows all end points that are available, Vera selectively hides them, why ? - I do not know, perhaps to much information is just that - to much info…
I’m not familiar with the HomeSeer GUI. Presumably you see all that on your screen shot, when you choose to go into the details area for “Node 19” the "Fibaro Light, which is good.
However what Ezlo are doing is just dumping the “Heat Sensor” as a child device into the main devices view / devices GUI area.
It opens as scroll down screen.
You start at the top and keep scrolling down or assign devices to rooms, floors or categories.
It can be changed to cards,
The child info devices are indicated at the top of the screen - look for the green ticks.
It really depends on which screen you decide to use as Main, in the end it really doesn’t matter as your home is smoothly automated and you have no need for switches or GU’s !..
Indeed, thanks for showing us those screenshots. That looks to be a better GUI as you have a device “details” area and a more basic main device view.
As the Vera / Ezlo GUI is quite bad in the mobile app, all the devices are on one page etc, scrolling and scrolling through lots of devices would only get worse, if I also have all these Heat Sensor devices appearing.
Although you can search to filter on a particular device.
The Vera mobile app GUI is mainly used for setup and configuration on Ezlo hubs, as their new Web GUI isn’t yet on feature parity with the old Vera UI7 Web GUI, as far as device settings and information goes and you can’t currently add new devices via their Web GUI.
With no Vera alternatives available here it was a no brainer.
The integrations are superior, MQTT and Node-Red completes a well rounded system.
Well worth a look.
I’ve used Node-Red a bit for somethings, not used MQTT however, not found a need to yet. All my devices are Z-Wave devices and I’m using Reactor as the logic engine.
Reactor doesn’t support HomeSeer, not sure if there are plans to. It does support Home Assistant however.
No, I have a hybrid system of a Vera lite and Edge with HomeSeer using Reactor. Originally I used PLEG (and still do in the Lite) - the entire system is very agricultural as it just been added to it over time and I never felt like de-commissioning something that was working well.
When the Vera’s die then I’ll move it all over to HS and use MSR with MQTT.
