I am just wondering if every z-Wave device that is mains powered is a repeater (I know the battery powered devices don’t repeat messages to conserve energy).
I have 10 of these EverSpring On/Off switches and I am not convinced that they are recognised by the Vera as routing data. I recently added a Horstmann Actuator and it is notable that the nightly heals look like this (node 49 is the new actuator) and all the rest are EverSpring On/Off switches. Why do I not see possible routes showing up that include something other than the Horstmann?
Thanks in advance for any info.
=======EDGE NODE PROFILE=======
Node: 3
Edge node: 0 score: 12 route: 1->0.0.0.0->3 num hops: 0 Latency avg: 103 max: 636 success 10 of 10
Node: 4
Edge node: 0 score: 47 route: 1->0.0.0.0->4 num hops: 0 Latency avg: 115 max: 327 success 8 of 10
Edge node: 49 score: 96 route: 1->49.0.0.0->4 num hops: 1 Latency avg: 110 max: 561 success 6 of 10
Node: 6
Edge node: 0 score: 5 route: 1->0.0.0.0->6 num hops: 0 Latency avg: 98 max: 190 success 10 of 10
Edge node: 49 score: 9 route: 1->49.0.0.0->6 num hops: 1 Latency avg: 101 max: 123 success 10 of 10
Node: 7
Edge node: 0 score: 5 route: 1->0.0.0.0->7 num hops: 0 Latency avg: 98 max: 190 success 10 of 10
Edge node: 49 score: 10 route: 1->49.0.0.0->7 num hops: 1 Latency avg: 100 max: 213 success 10 of 10
Node: 9
Edge node: 0 score: 5 route: 1->0.0.0.0->9 num hops: 0 Latency avg: 98 max: 190 success 10 of 10
Edge node: 49 score: 9 route: 1->49.0.0.0->9 num hops: 1 Latency avg: 99 max: 124 success 10 of 10
Node: 10
Edge node: 0 score: 5 route: 1->0.0.0.0->10 num hops: 0 Latency avg: 98 max: 190 success 10 of 10
Edge node: 49 score: 8 route: 1->49.0.0.0->10 num hops: 1 Latency avg: 100 max: 114 success 10 of 10
Node: 11
Edge node: 49 score: 8 route: 1->49.0.0.0->11 num hops: 1 Latency avg: 99 max: 102 success 10 of 10
Node: 12
Edge node: 0 score: 47 route: 1->0.0.0.0->12 num hops: 0 Latency avg: 311 max: 2420 success 10 of 10
Edge node: 49 score: 8 route: 1->49.0.0.0->12 num hops: 1 Latency avg: 99 max: 102 success 10 of 10
Node: 49
Edge node: 0 score: 3 route: 1->0.0.0.0->49 num hops: 0 Latency avg: 95 max: 102 success 10 of 10
