Irritrol PC Control
Has anyone been able to interface the Vera with the Irritrol controller?
The controller is normally programmed via USB, so it seems like it would be possible.
http://www.irritrol.com/pccontrol/
We have a few of these units installed. No way to control it from the internet as you have to have the remote within radio range. Its not a bad controller, but unless your system is 100% up-to-par wiring-wise, it will give you problems. It is very picky on it.
Irritrol still has some issues to work out with it (PC program is not the best, remote isn’t that powerful, etc.) but still not too bad.
