IrrigationCaddy plugin
It’s great to see all this cooperation, producing good outcomes. I’m happy to support that by making my plugins available on the appstore. When I get around to it, I’ll add the Broadlink MK2 plugin.
That would be great - the more the merrier! Thanks.
[quote=“rigpapa, post:35, topic:175826”]I’ve been getting peppered with this same question for my plugins. Apparently a lot of ImperiHome fans out there. I found this, and have implemented it for two plugins so far with no issues–easy to do.
ImperiHome ISS API: http://dev.evertygo.com/api/iss[/quote]
I created this [url=https://github.com/reneboer/openLuup-ImperiHome]https://github.com/reneboer/openLuup-ImperiHome[/url] to get ImperiHome linked with openLuup. It supports all standard types of devices and if you would set includeVeraBridge to true you could even remove your Vera(s) and do all via openLuup. It is also fairly simple to add support for any plugin. To access local is simple, but also remote is possible as you can read in the instructions.
Cheers Rene
Ooh, that looks nice. Perhaps you should start a thread under openLuup and I can make it sticky?
Hats off to you for using the WSAPI interface. It certainly makes adding server functionality like this relatively easy.
Hi akbooer,
I added a topic to your openLuup board [url=http://forum.micasaverde.com/index.php/topic,80039.msg379914.html#msg379914]http://forum.micasaverde.com/index.php/topic,80039.msg379914.html#msg379914[/url], but I cannot make it sticky. You can if you want to.
Cheers Rene
Done! This way, both you and I can edit, if necessary. Thanks again…
…I really must try ImperiHome!
I have one question not related with the plugin itself, but more to Caddy users.
Do you know what happened with cloud access to Caddy? It does not work since some time. I can control it only from local access not remote via cloud.irrigationcaddy.com.
Was the URL changed or the cloud service was stopped? However in GUI there is still information that cloud service is ONLINE.
