I had to use an Iris thermostat from Lowe’s after the CT100 I installed failed. I touched the screen, yes touched not pressed, and it shattered.
The Iris thermostat is manufactured by Radio Thermostat, same as the CT100. It’s model number is CT101 and it works with the Vera very well. The CT101 comes with a base plate that the CT100 does not and it improves the installation by having the wiring directly behind the plate instead of squeezed between the thermostat and the wall. The wire squeeze may have been the reason for the CT100 failure.
Using the WDSC_HVAC and Thermostat Min Max plugins are the reason I purchased the Vera. They both work well. Thank you SOlivas and mcvflorin for your time and effort developing them.
The investment in this system should pay for itself in electricity bills at my beach rental.
Check out SOlivas’s thread at http://forum.micasaverde.com/index.php/topic,15982.30.html
It is very informative.
