IR sender/blaster
I would really like to get some kind of IR sender/blastre that does not require me to install wires and mount these small senders on the IR receiver on all my equipment. Are there any products on the market that does this? I’d prefer mounting a small box or something in the ceiling and aim it in the general direction of my AV equipment, but I haven’t found anything like it.
Any ideas?
You could use SQ blaster, that works well, and you can use the individual leds which you put on the devices, but then you have the cables you dont want, but the base unit itself can act as a ir blaster, so if you mount it in line of sight it could control everything without having to have wires. If you research ehre on the forum though, there is a lack of development with SQ blaster, and it might be difficult to actually buy. I use it, and its a great product, but before you commit have a look on the website Square connect, and do some research on here. The advantage is you can use it via Vera, it does have a plugin, and you can control everything independent from Vera via ipad/iphone which i find great.
There is also the itach global, again, have a look on here. I do not know the product so not sure if it does wehat you want.
If you do not want/need Vera integration, i used a Philips Pronto before i ‘upgraded’ to SQ blaster. Works well, but in my opinion technology is obsolete now, but others will probably disagree.
These are just a couple of ideas
