IR Control to kick off a scene?
Hi all,
I’m new to the forum, and planning on getting a Vera3 in the near future. It looks like it will do everything I want it to, with one possible exception.
My plan is to have Vera control lights, etc from smart phones and tablets in my house. I would also like to be able to control my home theater equipment (likely through SQ Blaster), but I would also like to have a standard IR remote in the home theater locations as well. Is it possible to have some sort of IR receiver that passes commands back to Vera to trigger a scene. IE: pressing pause on the IR remote will send trigger Vera to turn on lights, pressing play will dim lights, etc.
I found one thread from a year ago that discussed this, and I believe a Vera developer said the code was written into Vera but commented out (unfortunately I can’t find this thread again), and I can’t seem to find a current thread with any further info.
In any case, is something like this possible, and if so, how do I do it? It’s the last piece of the puzzle I would like to figure out before I pull the trigger on a Vera.
Cheers,
Mike
Found the thread that I mentioned here:
[url=http://forum.micasaverde.com/index.php/topic,7113.msg45082.html#msg45082]http://forum.micasaverde.com/index.php/topic,7113.msg45082.html#msg45082[/url]
That was over a year ago though. Any possibility this functionality has been added?
Thanks,
Mike
I don’t do it directly through Vera, but use a PC with IR receiver which talks to Vera to turn on the lights with pause, etc.
I was actually just thinking about that. How exactly do you do it? Do you use USBIRT? What do you use on the PC to send commands to Vera? I have a media server in my rack that will be right by the Vera unit, so this is definitely an option for me.
A cheap HP MCE IR Receiver
http://img.alibaba.com/wsphoto/v0/299342076/NEW-HP-MCE-REMOTE-CONTROL-USB-IR-RECEIVER-IR-Emitter.jpg You can get them on ebay very cheaply.
http://www.eventghost.org/ in conjunction with XBMC & Media Player Classic-HC.
