This may be an incredibly basic question, but i’m having such difficulty finding the answer.
Have the USBUIRT hooked up to my vera lite. I need to have 4 basic functions :
- turn on
- turn off
- turn on 3d mode
- turn off 3d mode
to accomplish 3+4, i need to make a macro that will press the 3d button - directional down - select.
I’ve programmed 3d button and the select button no problem.
But the directional down pronto code repeats the command 3 times. Since the 3d menu is only 3 options, it just cycles back to the top.
i’ve been using the USBUIRT learner program as well, but each code i ever get for the down button has 3 distinct presses
Oh, and i can’t create a custom remote and learn commands for some reason. Vera support suggested i send the pronto codes.
So, here’s the question :
Can i update a pronto code to only send the command once?
Anyone have any ideas?
