IR Capabilities of Leviton Zone Controller
I have a Leviton VRCZ4-M0Z Z-Wave 4-Button Zone Controller installed and working perfectly to trigger various scenes. The description of this controller online states that it is a Zone Controller for Multi-Location Control with IR Remote Capability.
I see a couple of IR remotes online that could be the correct one, e.g. the Leviton VRMR1-OSG and the NE210. Neither of these come up in the Harmony remote database. Is there anyone here who uses this zone controller with IR and can tell me what remote to search for in the Harmony database? There seems to be no way to extract a list of all Leviton lighting controllers in the database. Thank you.
Marc
The first model is the one Leviton lists as the IR remote for the controller.
The second appears to be for the D3200 line of controls.
MarcM001
is your leviton VRCZ4-M0Z triggering scenes on vera 3 ?
my question is because I need wall scene controllers what runs fine with vera3.
thanks for your information.
[quote=“MarcM001, post:1, topic:173772”]I have a Leviton VRCZ4-M0Z Z-Wave 4-Button Zone Controller installed and working perfectly to trigger various scenes. The description of this controller online states that it is a Zone Controller for Multi-Location Control with IR Remote Capability.
I see a couple of IR remotes online that could be the correct one, e.g. the Leviton VRMR1-OSG and the NE210. Neither of these come up in the Harmony remote database. Is there anyone here who uses this zone controller with IR and can tell me what remote to search for in the Harmony database? There seems to be no way to extract a list of all Leviton lighting controllers in the database. Thank you.[/quote]
I’ve been using an older Leviton controller RZCS4-1LX with a harmony remote, and it works fine, although the IR window on the controller doesn’t accept signals from very much off-angle. In the harmony database, don’t search for the Leviton remote, search for the zone controller itself, and you should find it.
Graham
I will check the VRCZ4-M0Z.
for me only is necessary trigger created scenes in vera3.
IR function is not necessary.
thanks !
