They’re a pretty penny, but look like a great way to mount an iPod in-wall as a permanent home controller. If I had unlimited funds, I’d put one of these in each main room with an iPad or iPod Touch running HomeWave.
EDIT: I’m VERY interested in solutions others have found for in-wall iOS device mounting. Thanks!
i’m very interested in this as well - there seem to be a decent number of options available but curious about anyone’s real world experience? i have an ipad 1 that i’d like to mount on the wall and run roomie/sqremote/homewave/something but the mounting (and power) bit are obviously critical to this plan…
I made my on wall mount for my Samsung Tab 2 7" Tablet. It was fairly easy once you get power to the device which I used a power over Ethernet device. I cut a hole in the drywall the same size as the tablet plus a small cut out to accommodate the power cable. Screwed a board on the back to support the tablet and used double sided tape to attach the tabled to the board behind the drywall. I then modified a picture frame, cutting off the sides using a Dremel tool to make the frame flush and attached with Velcro.
I was first leaning towards an Android tablet and I still think it would have worked out really well but Home Wave is just too cool. I’ll be officially confiscating the 2nd gen iPad from my wife (of course I’ll have to replace it) and installing it in an IW2000 mount.
Yes, definitely too good to be true. I guess this so called fit kit allows an iPad2/3 to be installed in the IW2000 (who knew). Here’s what you get and it was actually $29…
[i]"Description:
The CM-IW2000 fit kit for iPad 2 allows an iPad 2 to be mounted in the CM-IW2000 in wall mount. This kit is also compatible with the iPad 3 if the foam spacers are not used.
Physical Condition:
This item is in excellent condition and works perfectly. All pieces look brand new and the foam spacers have not been used.
