I am running the latest version of UI4 (1.1.1047) and iOS 4.1. I have the fully paid iVera for the iphone. Everything works ok for a few days and then the app is no longer able to connect. The only thing that works to fix it is to reboot the Vera box.
Why is this happening and what’s the solution? it’s really annoying!
thanks
Gene.
I’m having exactly the same issue. But it also seems to be a problem with cp.mios.com not just iVera. Reboot works fine on cp.mios.com or iVera fine for a while then gets unreliable and “server busy” messages etc… and eventually needs another reboot. This all started for me over the holidays. I’ve seen many other messages in the forums to the same effect.
