iphone can't connect with version 1.1.1047 .
Thank you again for your file, but I must confess my lack of programming expertise.
I have the configuration utility, but I don’t know how to get this file you provided into my iphone.
You should open this post with your iphone and then open the attachment with your browser. Alternatively, you can download the file to your computer and email it as an attachment to an accout your iphone is connected with, then open it with the iphone.
I installed the mobile config but still get a crash. Iphone 4 os 4.0.1. Anyone having success with this?
Mobileconfig worked perfectly.
Thank you for the help!
What phone and version of ios are you guys using?
When I go to MO and enter the same credentials as the normal site I get a message that my credentials are wrong. I ahve the smrtphone plugin installed.
Any ideas?
I’m using iPhone 3G with latest firmware.
I also have the smartphone and basic mobile interface pugins installed on my vera 2.
All works well but i have now stated using iVera with good results.
I have an iphone 3GS with latest OS. I have installed the mobile config but still can not log in to either cp.mios.com or MO. I get the security lock icon and the progress bar starts to advance but before the page is displayed, Safari crashes. Installing the mobile config solved the certificate problem but I am still unable to get to my mios account login screen. Any thoughts?
FrankHill: thanks for the file. Finally got the background and icons to load in the Smartphone interface on my iPhone.
.//A.
Since of 30 September https://cp.mios.com should work directly on any smartphone, without requiring to do any other configs.
If you still have problem with it please test individually:
https://cp1.mios.com
and
https://cp2.mios.com
and submit a trouble report with the website that’s working/not working and your smarthphone Make/Model and OS version.
hi cj, MO works in my iphone now. i will test this remotely (away from my home). thanks.
