Hi is there a problem with the server I am getting " cannot connect to MYsQL server ERROR!
I have been seeing the same error since Friday May 14. Still not working as of Sunday May 17 evening. Glad to know it’s just not me getting the error.
knock knock micasa…
Is there a problem here!!
I am also having this problem… I assume you guys have already submitted a support ticket.
I have not put in a support ticket. ZMISTRO, have you?
I did, micasa should be aware.
Fixed for me, thanks.
Yes, fixed for me as well. Thanks to ZMISTRO for posting and thanks to BOSSTON for submitting a ticket.
Has anyone noticed that when looking at the Thermostat on the iphone, the readings are not in Farenheit? Right now it says TEMP=26. But when I look at the main dashboard you log into, it says 79?
Does anyone else see this too, or is it just some setting I need to fix on my side?
All the commands are sent in Celsius.
For the moment on the iphone/mo app the temperature it’s displayed also in Celsius and there isn’t an option to change it for the moment.
We’ll add this option too.
