I am honestly not sure where this belongs, but I thought I would start in the Dev section. I currently have over 65 UPB devices which have been in successful operation for over 6 years. I also use Sonos and have an extensive whole house DirecTV installation. A few years back, I upgraded to the newest Honeywell Ademco Alarm panel and new touch screen devices, two new Trane thermostats and a number of Schlage electronic deadbolts along with a Vera2. This year I plan to add motorized shades for a number of new windows as well as some IP cameras on the perimeter of home. As you all know, integration of all these devices is the challenge.
My quest is to attempt to use Vera as the central hub, as I currently have a number of separate ios apps which control everything above (Roomie for all A/V-related equipment and UPB lighting, Honeywell app for the alarm, & Homewave for Vera climate and lock control) on a number of ipads and iphones. My next step is to add the Honeywell extension for Vera, but lighting is still elusive. All of my scenes and switch control are done thru a Web Mountain UPB gateway (RUC-01) which can accept simple hex strings via IP message packets sent to a specific web / port address (e.g. - 192.168.1.5:9761) - I am now successfully able to control the RUC-01 from various ios products like Roomie, iRule, & DemoPad.
My question is whether anyone has developed a programming extension/plugin for Vera, which allows for sending and receiving IP message packets via ethernet or wireless? If not (as I am not a programmer) how difficult would it be?
Thanks for any feedback and/or suggestions you can offer.
There isn’t a generalized Plugin that sends IP-based messages, but almost all of the Device-specific Plugins actually end up doing this.
There are a lot of variations in wire-format requirements across Device-types, so your best bet would be to read, and “adapt” one of the existing plugins that performs a function “nearest” to what you’re looking to do.
Most of the plugins have a presense over on http://code.mios.com where you can look at their source code. They tend to be categorized by function, which can help you find one that performs the right functions for what you’re looking to integrate. Beyond that, the other plugins, even if they don’t do/expose the specific function your looking to implement, will likely have the required wire-format technique.
Some folks here have used these to mash up a baseline of code for what they need, and then looked for assistance on how to fix it
Most plugins were written by Programmers that have Vera, and were already looking to integrate something already present in their house(s).
Thanks for the good input. The challenge is that I am not a coder, so am not sure that looking @ code will give me any great insight without some basic education. I have hacked some XML together for other projects, but it was not pretty.
I was a bit surprised that I found very little, if any, reference to UPB on the boards here, given that it is a very stable technology, with little-to-no issues (at least in my install) and has a relatively large installed base of users. After having worked with ZWave for past 2 years, I can also attest to fact that UPB is a much simpler protocol to work with.
That being said, I still need to find a way to centrally manage my UPB devices, along with my ZWave (and potentially other) technology sub-systems. Tradeoffs are the hallmark of any integration effort, so I am not expecting nirvana.
Until someone develops a Vera UPB-specific plugin, I will probably need to explore other alternatives outside the Vera ecosystem to stitch the 2 systems together. Interestingly, the proliferation of the mobile devices and tablets has created a design/development ecosystem which appears to have good support and is expanding quickly.
