IP camera support
There are a number of new IP video devices coming onto the market that support the emerging ONVIF (Open Network Video Interface Forum) and/or PSIA (Physical Security Interoperability Alliance) standards. I am wondering if there are any thoughts by you guys about supporting devices using these interfaces.
Note: ONVIF uses SOAP based communications while PSIA is UPnP/HTTP oriented which may be a better fit for LUUP. Howerver, it does look that ONVIF is going to be more prevalent.
TIA, /ted
