IP Camera FPS (Frames Per Second)
HI,
I installed the D-Link DCS910 IP camera. But, it seem like the fps (frames per second) is very low. How to set it up to at least 25 fps? I already set 30fps in the IP camera firmware setting , but the video I got is still slow. Please help.
You can’t set such a higher value in order to see the images on the dashboard or in the View Fulls Size window. The default value it’s a picture at 5 seconds. Setting to a lower value can cause system instability.
