Invalid message error. Plugin does not process status.
All of a sudden plugin does not read my Vista 20p status. I can still control the panel (arm, disarm, see sensor statuses, etc.) but panel status is not being red. In Vera log the following error is logged:
luup_log:73: (VistaAlarmPanel::processIncoming) ERROR: Invalid message. <0x7303f520>
This started recently, probably after the last update… anyone else on the recent plugin version and has the same issue?
Hi ykamenet,
Here you will find a potential fix or use the request to downgrade the plugin to 3.12 version.
Regards,
  • Andrei -
