ok so i bought a 6 pack of these on ebay a while ago after getting someon on here posting how cheap they were. i didnt get around to installing 1 until the other night. the zwave can control it and it does work… sorta. idk if it s a bad switch or if i accidently did some kind of odd programing to it when i set it up somehow… but to turn it on i have to click it twice. and to turn it off i have to click it twice. if i dont it turns on for couple seconds then turns off then turns back on and continues this lupe until i double click it either on or off. it even does this if i send the commad through the vera system. ie i have to click the button on or off twice very fast for it to actually tur the light on or off or it goes into the same lupe. does anyone know how to fix this? the programing guide for the switch doesnt seam to exist from what i searched on google. and i cant seam to find anyone else who has this issue.
@dohcdragon is this wired into a 3 way setup or just a stand-alone switch?
just a stand alone
ok after a lot of testing and messing around I figured this out… and I had a few people email me more recently asking if I fixed it so seeing how I figured it out I figured I would post it here. these switches are nice but they have issues… when you install them you need to make sure that there is plenty of room on all sides of the switches. if anything is pressing on the plastic at all they will malfunction and go into a on off loop. good luck all I can say is I hat to replace the electrical boxes in my house to fix the issue and it worked flawlessly after I did that.
