Intermixing Brands of Switches
Hello again, everyone.
I have a Cooper 9540-n on order to test with dimmable LEDs. I’m hoping that I don’t get buzzing. But if I do, my backup plan is the Leviton VRE06-1LZ (albeit much more expensive).
However, for lights (or fans) where I don’t need dimming, I was hoping to go with a Jasco/GE 45609 or similar because they are relatively affordable. (relative being the key word, here - none of this stuff is cheap! LOL)
Anyway, my concern is aesthetics and “wife approval” when mixing brands. It appears that the Jasco unit has a blue status LED while the Coopers have an amber. To make things even more complicated, it appears that the Leviton is green.
Has anyone dealt with this successfully? Are there combinations that fit decent together? I thought about even changing the LED but that is probably getting a little involved. The Cooper “ON/OFF” switch is almost as much as their dimmer (likewise although not quite as bad for Leviton).
This is why I stuck with one brand (Leviton for me). I would also consider the design of the paddles. Levitons is shaped like a normal decora switch (The bottom pokes out). I kinda like this because most people understand that you push that part down. The flat ones I’ve just had people stare at them confounded.
That being said, I think I’m going to move all my switches to insteon since I’ve found out you can set the dim level without turning on the light (so I can say "between 11pm and 7am, turn on to 20% if turned on locally, else turn on to 100%).
Thanks, Sir.
I have a feeling that’s going to be the common answer.
I’m starting to lean towards Leviton as well (even though I have a Cooper 9540 on the way). I’ve been trying all week to get a hold of a Cooper tech support person to ask some general questions about their product line and have received NO return call. (VMs only)
I may just pay the Leviton premium and be done with it.
I will say that I’ve been happy with both my VRIs (2 wire) and VREs (3wire) Levitons. If it wasn’t for not being able to set the dim level without turning on the light, I wouldn’t even be considering the insteon ones.
[quote=“tbully, post:3, topic:179377”]Thanks, Sir.
I may just pay the Leviton premium and be done with it.[/quote]
I have gone cheap and use a lot of the GE for basic ON/OFF. I just turn off the LED if it is bothersome (bedrooms or next to another device where I want the LED on). The GE hot-only dimmers are not really friendly to low energy alternative lighting like CFL or LED, so they don’t have a place in my setup.
I disable indicator LEDs whenever possible.
For GEs the LEDs are off completely after installation. I hate hate HATE the incredibly bright blue LEDs on any device, but I definitely won’t tolerate my light switch indicator alone illuminating what is supposed to be a dark bedroom or theater. Disabled! If I didn’t have the configuration option I’d physically break or blackout the LED.
Leviton LEDs come on when activated, but are configured to turn off after 5 seconds.
Linear/Evolve don’t completely disable the LEDs so they are configured to turn the LED on when the lights are on. I am not distracted by their green LED in a lit room. If I were, I’d drill or blackout the LED.
Cooper - I haven’t worked with these, but I don’t think the LEDs are configurable.
[quote=“Z-Waver, post:6, topic:179377”]I disable indicator LEDs whenever possible.
Cooper - I haven’t worked with these, but I don’t think the LEDs are configurable.[/quote]
I agree with the hatred part, but I must confess that they have replaced the night lights in the kid’s and guest bathrooms and along the hallway (outlets placed to extend the zwave range). Yes, those LEDs are BRIGHT!!!
I read that you can flip the action of the light on the GEs (“LED on” when load on or “LED on” when load off) but I didn’t know that you could disable it. It looks like the Leviton are very similar to normal paddle switches so they may coexist OK (with their lights disabled).
I suppose I could always black them out somehow, too. Good idea.
[quote author=tbully link=topic=23097.msg156437#msg156437 date=1391876634]
[quote=“Z-Waver, post:6, topic:179377”]I read that you can flip the action of the light on the GEs (“LED on” when load on or “LED on” when load off) but I didn’t know that you could disable it.
I suppose I could always black them out somehow, too. Good idea.[/quote]
For GE switches, yes you can turn off the blue LED all the time:
  1. On the MiOS dashboard click the wrench in the top right corner of the GE dimmer device you’d like to alter.
  2. Select the “Device Options” tab
  3. Click the “Add configuration settings” button
Three new fields will pop up along with an “X” delete button. The fields from left to right are “Variable”, “Data Size”, and “Desired Value”.
  1. In the “Variable” field put a “3”.
  2. The “Data Size” field is a drop down list, click it and change it to “1 byte hex”
  3. In the “Desired Value” field put a “2”
  4. Close the settings for the device by clicking the “X” in the top right (the “X” is to the right of the trashcan and question mark icons, not the “X” to delete the Configuration you just created).
  5. Click “Save” in the top right of the MiOS dashboard.
Give the GE Outlet about 30 seconds and the blue LED will now be off if the switch is off all the time."
quoted by a post from @beryllium
this works.
I had a mix of the Evolve Dimmers and Leviton.
The Evolve have an up paddle and a down paddle. Double tapping up or down turned them full on or off.
Leviton as others have mentioned, has a simpler buttom tap only (dimmer on a horizontal control on the top). Having one way to turn on or off the light definitely helped in the WAF. However, we rarely use light switches as we are 100% motion controlled (or contact sensor for closet doors) to turn lights on.
Since then, I’ve moved all the Evolve switches to backend functions like 3 floodlight controls in Garage…which normally controlled via scenes.
I did spring for the low voltage Leviton dimmers as we went 100% LED, that sadly were a little more than I wanted to spend and I had some initial problems with bulbs buzzing and wanted to play it safe. I think I’d look for LED that are dimmable using normal dimmer (non-low voltage) switches (they now make them, look at reviews on Amazon before you buy) which are half the price of low voltage models.
Update on my conundrum…
My Cooper RF9540-N came in last night. I installed it in the master where I have my first set of LED BR30’s. I bought these lights a few months ago before I started to ramp up my Vera/Automation stuff:
[url=http://www.amazon.com/dp/B008NNZSI0/ref=pe_385040_30332200_pe_309540_26725410_item]http://www.amazon.com/dp/B008NNZSI0/ref=pe_385040_30332200_pe_309540_26725410_item[/url]
I’m happy to report that I have no buzzing or flickering at this time. There is one bulb that stays lit longer than the others as I reach minimum dim but I noticed this on my normal dimmer which was just replaced. I believe there is a way to set “minimum dim level” (or something to that effect) so it shouldn’t be an issue. I blame the bulb here, anyway.
The switch (with the faint blue LED lights) seemed, to my surprise, to pass the WAF test. I therefore may end up going with the Coopers.
With that said, I do have about 18 switches I need to purchase (10 of them being these dimmers with their companion) and then a few on/off’s for fans/garage lights/etc. I generally believe in “you get what you pay for”.
So before I dive in to this purchase, I’m trying to figure out why Leviton gets so much more for their comparable VRE06-1LZ dimmer. Ascetically, they are both “fine” according to the wife. I actually think I lean a little towards the Leviton, personally, but not at double the cost.
The question is: Those of you who have heavily researched and/or tested the Levitons…what makes them so pricey/special?
Because they’re crooks(they’re all crooks) and we still pay them. There’s no reason for any of these Z-Wave switches to cost even half of what we seem willing to pay.
Competition is increasing and hopefully we’ll start seeing some effective price pressure.
@tbully, I was in the same boat as you, trying to decide what brand to get, and the Coopers look really nice and are way less expensive, so I wanted to go that route. Sadly, I had really loud buzzing from all my bulbs, and I tried 3 different Cooper RF9540-N switches and 7 different brands of LED bulbs all with the same problem.
What’s the batch/date of the Cooper that you have? Curious if you got a newer batch. Mine were all from the same batch, either August or September 2013.
Before you buy more Cooper dimmers, I would suggest trying the switch you have with other bulb types fixtures that you will be using in your home. I assume they’re not all BR30’s and you probably have some A19’s as well. Better to test those as well before you spend too much on switches and go “all in” with a particular brand.
The Levitons VRE06’s work for me without buzzing, but the price is nuts. Thinking of trying some Evolve’s, but don’t want to give up instant status.
I will happily pull the switch from the wall and get the batch / date for you. If it is a batch/date issue, I’ll be concerned that my next order is of the “newer” revisions. ::slight_smile:
I actually have mostly BR30s but do have a few A19s too. Good idea on testing a few other bulbs.
I do need status in most cases so I’m tied (at this time) to either Leviton or Cooper. As I stated above (or maybe it was another thread), I’ve been completely unable to contact Cooper support so part of me does want to go to Leviton. I also like the ability to “program” the LED behavior (shut it off after a bit of time). The single button push is also very nice.
But, as Z-Waver said, they are (all - not just Leviton) crooks and I’m not sure I can stomach paying almost double for the Levitons…maybe… :slight_smile:
All-
Kelly over at HA World has been doing some great, comprehensive real-world tests on what Z-wave dimmers work well with what LED light bulbs. So far he has tested Leviton and Evolve dimmers. Have a look here:
Hope this helps,
-TC
Most of my switches are various Cooper ones. I also have some wall outlets and plug in modules. I have one bathroom with 4 switches/dimmers that are Leviton from when I was first testing them out. I like them both but for different reasons, I went with Cooper in the end.
They each have programmable features but I liked the Cooper features a bit more. Cooper also has a larger variety of devices for my needs. I wanted to stick with one brand as much as possible as I would also be buying a secondary branded controller to do much of the individual device programming outside of Vera. The brightness indicator on the dimmers were much brighter on the Cooper. The indicator is dark enough on the Leviton that its diffcult to see the set level without looking closely. The Cooper was more obvious to me. I also liked that the Cooper dimmer toggle was easier to actuate. The Leviton toggle is very hard to press, and the button is tiny. I do like the Leviton’s nice click better, and even the design, but in the end it wasn’t enough.
They are both running LEDs for my use. Most of my LEDs are Philips brand. I haven’t had any issues with buzzing.
I use Fibaro controllers and make my own switch plates. These buttons are lighted, but I do not power them.
Thanks Katmai.
I just got a Leviton in today. Unfortunately, I think the wife may like it better than the Coopers because I’m with you. I think the Cooper is a little better in regards to dimmer level and “mixes” better with non-zwave switches. (their Aspire on/off non-zwave switches are ~$2.00 at Lowes!!)
I’ve done some quick Google Searching and can’t find the answer…do you happen to know how to program the more advanced feature-sets on the Coopers and Levitons?
(I can’t wait to try out some Fibaro stuff - looks cool)
The advance feature sets on the Cooper and Levitons can be programmed directly through the switch itself (I have a couple of Levitons). Unfortunately, MCV has dropped the ball in terms of accessing these feature sets through Vera, I recently posted about this. They supposedly struck a deal with Leviton to support the advance features (dim ramp rates, max brightness levels, etc), but nothing ever happened. This was 3 to 4 years ago. ::slight_smile:
Leviton does sell a programmer for their switches, the idea is that once setup, Leviton switches and devices don’t need a central controller. [url=http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=38971&minisite=10251]http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=38971&minisite=10251[/url]
-TC
Actually the Cooper switches are only programmable through their own brand controller. Its an okay controller if you can find one cheap (I got mine on ebay), but I wouldn’t pay full price for it. I invested in one as I was buying so many of their branded products. Its the same as most controllers in terms of setting up scenes and the like, plus some other features specific to the Coopers. Unfortunately the different brands of controllers cannot access other brands, so my Cooper controller can’t set or see anything in terms of programming with the Levitons other than turning it on and off). Kind of a bummer. Same with Vera not being able to get into the programing.
Programmable features of the Coopers switches are:
Off delay
All on and all off function
Panic on time
Panic off time
Power on state
Ramp time
The levitons are programmable through some switch combinations and also from their own controller. Its in the instructions on how to do it from the switch.
I think either way they’re both good brands. The Coopers just appealed more to what I was looking for.
I guess to answer the original question, I think mixing switches is fine. They’ll work, but there is a chance their features may not be compatible or identical to each other.
On a side note anyone see the Legrand Adorne line of swtiches at Lowes? They’re so neat looking. I wish they were z-wave!
