Intermittent PLTS device creation errors
I just noticed a number of these (sorry, fair number of DUPs as this is a case of me doing a simple grep on a number of hourly dumps of the Vera LuaUPnP.log file)
I looked for error statuses and found this because I’ve been having issues with one of two things; It’s either PLEG not firing the event or the iPhoneLocator plugin crashing (difficult to say which it is, even with a fair bit of logging turned on, so I’m not indicting PLEG! But I am wondering if these errors may be related in some way…?)
It seems like a reboot causes the problem to go away (and I have a few of those it seems, due to deadlocks)
LuaUPnP-20140220-12.log:01	02/20/14 11:17:26.764	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-12.log:01	02/20/14 11:17:26.765	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b270000>
LuaUPnP-20140220-12.log:02	02/20/14 11:17:26.532	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-12.log:02	02/20/14 11:17:26.533	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-12.log:02	02/20/14 11:17:26.765	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-13.log:01	02/20/14 11:17:26.764	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-13.log:01	02/20/14 11:17:26.765	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b270000>
LuaUPnP-20140220-13.log:02	02/20/14 11:17:26.532	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-13.log:02	02/20/14 11:17:26.533	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-13.log:02	02/20/14 11:17:26.765	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-14.log:01	02/20/14 11:17:26.764	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-14.log:01	02/20/14 11:17:26.765	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b270000>
LuaUPnP-20140220-14.log:02	02/20/14 11:17:26.532	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-14.log:02	02/20/14 11:17:26.533	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-14.log:02	02/20/14 11:17:26.765	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-15.log:01	02/20/14 11:17:26.764	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-15.log:01	02/20/14 11:17:26.765	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b270000>
LuaUPnP-20140220-15.log:02	02/20/14 11:17:26.532	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-15.log:02	02/20/14 11:17:26.533	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-15.log:02	02/20/14 11:17:26.765	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-16.log:01	02/20/14 11:17:26.764	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-16.log:01	02/20/14 11:17:26.765	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b270000>
LuaUPnP-20140220-16.log:02	02/20/14 11:17:26.532	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-16.log:02	02/20/14 11:17:26.533	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-16.log:02	02/20/14 11:17:26.765	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-17.log:01	02/20/14 11:17:26.764	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-17.log:01	02/20/14 11:17:26.765	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b270000>
LuaUPnP-20140220-17.log:02	02/20/14 11:17:26.532	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-17.log:02	02/20/14 11:17:26.533	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-17.log:02	02/20/14 11:17:26.765	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-18.log:01	02/20/14 11:17:26.764	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-18.log:01	02/20/14 11:17:26.765	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b270000>
LuaUPnP-20140220-18.log:02	02/20/14 11:17:26.532	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-18.log:02	02/20/14 11:17:26.533	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-18.log:02	02/20/14 11:17:26.765	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-19.log:01	02/20/14 11:17:26.764	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-19.log:01	02/20/14 11:17:26.765	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b270000>
LuaUPnP-20140220-19.log:02	02/20/14 11:17:26.532	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-19.log:02	02/20/14 11:17:26.533	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-19.log:02	02/20/14 11:17:26.765	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-20.log:01	02/20/14 11:17:26.764	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-20.log:01	02/20/14 11:17:26.765	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b270000>
LuaUPnP-20140220-20.log:02	02/20/14 11:17:26.532	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-20.log:02	02/20/14 11:17:26.533	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-20.log:02	02/20/14 11:17:26.765	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-21.log:01	02/20/14 11:17:26.764	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-21.log:01	02/20/14 11:17:26.765	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b270000>
LuaUPnP-20140220-21.log:02	02/20/14 11:17:26.532	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-21.log:02	02/20/14 11:17:26.533	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140220-21.log:02	02/20/14 11:17:26.765	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b270000>
LuaUPnP-20140228-01.log:01	02/28/14 0:10:32.487	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b1d3000>
LuaUPnP-20140228-01.log:01	02/28/14 0:10:32.488	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b1d3000>
LuaUPnP-20140228-01.log:02	02/28/14 0:10:32.264	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b1d3000>
LuaUPnP-20140228-01.log:02	02/28/14 0:10:32.265	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b1d3000>
LuaUPnP-20140228-01.log:02	02/28/14 0:10:32.488	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b1d3000>
LuaUPnP-20140228-12.log:01	02/28/14 11:26:47.773	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-12.log:01	02/28/14 11:26:47.773	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b09e000>
LuaUPnP-20140228-12.log:02	02/28/14 11:26:47.553	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-12.log:02	02/28/14 11:26:47.554	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-12.log:02	02/28/14 11:26:47.773	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-13.log:01	02/28/14 11:26:47.773	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-13.log:01	02/28/14 11:26:47.773	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b09e000>
LuaUPnP-20140228-13.log:02	02/28/14 11:26:47.553	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-13.log:02	02/28/14 11:26:47.554	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-13.log:02	02/28/14 11:26:47.773	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-14.log:01	02/28/14 11:26:47.773	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-14.log:01	02/28/14 11:26:47.773	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b09e000>
LuaUPnP-20140228-14.log:02	02/28/14 11:26:47.553	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-14.log:02	02/28/14 11:26:47.554	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-14.log:02	02/28/14 11:26:47.773	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-15.log:01	02/28/14 11:26:47.773	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-15.log:01	02/28/14 11:26:47.773	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b09e000>
LuaUPnP-20140228-15.log:02	02/28/14 11:26:47.553	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-15.log:02	02/28/14 11:26:47.554	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-15.log:02	02/28/14 11:26:47.773	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-16.log:01	02/28/14 11:26:47.773	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-16.log:01	02/28/14 11:26:47.773	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b09e000>
LuaUPnP-20140228-16.log:02	02/28/14 11:26:47.553	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-16.log:02	02/28/14 11:26:47.554	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-16.log:02	02/28/14 11:26:47.773	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-17.log:01	02/28/14 11:26:47.773	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-17.log:01	02/28/14 11:26:47.773	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b09e000>
LuaUPnP-20140228-17.log:02	02/28/14 11:26:47.553	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-17.log:02	02/28/14 11:26:47.554	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-17.log:02	02/28/14 11:26:47.773	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-18.log:01	02/28/14 11:26:47.773	Device_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-18.log:01	02/28/14 11:26:47.773	JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 215/D_ProgramLogicC.xml so device 215 is offline <0x2b09e000>
LuaUPnP-20140228-18.log:02	02/28/14 11:26:47.553	JobHandler_LuaUPnP::FetchMissingFiles need to download D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-18.log:02	02/28/14 11:26:47.554	JobHandler_LuaUPnP::m_sMissingFile_set D_ProgramLogicC.xml <0x2b09e000>
LuaUPnP-20140228-18.log:02	02/28/14 11:26:47.773	JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_ProgramLogicC.xml <0x2b09e000>
Looks like your Auto Updates failed … maybe some network problems (Yours or MCV) … or maybe it’s low on memory.
Vera tries to verify files when it restarts … so it should eventually clear up.
