I’ve started noticing that the authentication service used on UI6/MMS will intermittently fail to authenticate credentials. I’ve reached out to the Vera folks for more info. I am suspecting there is some kind of throttling happening but i haven’t figured out the pattern. All this means is you need to wait a moment and try again. I’m going to try to update the app with some better messages to hopefully make it more clear. Thanks.
Spencer ![]()
