Hello, I am giving this information because I to have tried to connect up the Intermatic PE653 to the Veraegde with no success. All I wanted to do is be able to put my Pool in what I call Spa mode remotely away from home (Switch the valves, turn on the main pump and heater) all done by the PE653.
The information below is a way to remotely run the 5 functions (Relays) of the PE653 using the Veraedge as the controller and associated Z-Wave Relays. (NOTE this does not give any feed back as to TEMP, TEMP control, Status of button Position “on/off” within the PE653)
Simple explanation of what I did is I HARD wired directly to the 5 momentary switches located on the PE653 front control board (See Photo) and installed Z Wave momentary relays to act as though you where standing in front of the Intermatic PE653 pushing the buttons!!!
Solder wires to the top left pin of all 5 switches. 1 Common wire can be attached to the Bottom of any switch or to the solder hole I found on the board as seen on the Photo.
NOTE: You must use a MIMOlite relay on Switch 1. MIMOlite allow the relay to act as a “Momentary” Switch. Set the Scene control in the Veraedge to “When turned ON to immediately turn OFF” Remove the J5 jumper as stated in the MIMOlite instructions that turns this unit into a Momentary Switch. This relay reacts very fast which is what the Switch 1 on the PE653 works best (Quick ON then OFF). If there is any long delay and the relay holds closed too long then it will not trigger the internal relay in the PE653 or will lock it up. (You must have access to 120V outlet. MIMOlite has 9V power transformer)
I used a ZMF-80 (Wired to 120V) on the other switches with no problems and set the Scene control also in the Veraedge to “When turned ON to immediately turn OFF” You can use MIMOlite on all the switches if you want but they are more expensive than the ZMF-80.
ENJOY RUNNING THE PE653 FROM YOUR SMARTPHONE OR TABLET!!
