Intermatic CA300 Status LED control
Hello all,
I have a house full of Intermatic CA3000 on/off switches. There are LEDs built into the switches that blink from red to blue when the switch is not set up on Vera. Once it is connected to Vera they turn off. Is there a setting that I can use to keep the LEDS lit when the switch is off?
Trolling the forum I saw a setting to accomplish this for GE 3-way switches. I tried using those settings with the CA3000 with out any results. Any help would be greatly appreciated!
