Hello,
I need to make several changes on the UI5 interface. I was looking in the files a lot but I can’t find where are generated the buttons in the top menu - DASHBOARD | Devices | Automation | Apps | Users | Energy | Setup . I tried to hide the setup button with jQuery like that:
Nothing happened. I guess that the content is generated a lot after the document is ‘ready()’. I searched the JavaScripts for id’s like #menu or #buttons but I wasn’t able to find where it is generated from.
Any suggestions?
P.S. Have anyone worked on a simplified version of the MiOS interface. Something light and cross-browser compatible?
What you are trying to do is Hard. The UI5 JavaScript is a veritable maze, and if you want to learn how it all hangs together then you’ll be spending hours in front of Firebug. I tried, and decided that life was better spent doing other things.
Back up a step and tell us what you want to achieve and we might be able to point you down a different path.
I fully agree with you, but just mention lots of the things are generated in the animate.js. If anyone else is trying to translate or change something on the interface ui5/animate.js is the key.
